I have a small study and now that the windows are in, its not clear how best to render the walls, some with existing plaster (25mm - 30mm deep). The backboxes are flush with the old plaster level.
The builders want to do option 3 below, but other options might be:
- Remove old plaster, back to brick, then dot & dab with plasterboard? However, the old plaster is quite hard, a cement plaster mix, so the face of the brick likely to be lightly damaged; does this matter?
- Dub out levels, tape joins and then apply render & skim finish (bonding the old plaster appropriately)? Should it be possible to achieve levels relatively easily? Would cracks open up and the overall finish be impacted?
- Dot & dab to existing plaster, which reduces the width of the room further (40mm forward of the old plaster level and back box), and up to 70mm to the brick in places (not great for fixings in the future)
