grand wizard said:kirk is right they used to teach you at bg to dot out they used a black pad you pushed into the dot and line them thru
could someone give me a guide price for 250 mtr of dot & dab please I know theres a differance in the country variants at the moment it purley for guidance
60 quid a sheet, or give them a mr jass price..... First name Hugh?could someone give me a guide price for 250 mtr of dot & dab please I know theres a differance in the country variants at the moment it purley for guidance
hahahaa, tha was funnyRe: A GUID TO DOT & DABBING
we worked for a bloke who had some cowboys in and said he knew there was something wrong when they called it dib and dobbing lol
Old thread mate , welcome new member when I read the op I thought I'd found someone madder than me buy you'll do if you can tell me about foam dabbingThere's another version of the dots I've come across; put screws straight into the blockwork, no plugs.
You can move them in or out until they're right, and/or tie the chalk line to it to set the level of the rest. Came across this when some cowboys fixed fireline to a fireplace wall with expanded foam.
I confess - I also used this once, to guarantee the air gap that Andy mentioned, behind vermiculite boards inside a fireplace.
Did a house in wales Addy DND BC came and I asked how many fire fixings ( got my own method ) , he looked at me puzzled , unsure of what I was talking about and replied " oh yeah, sounds OK to me " , only 5 years ago , another world in them valley'sAh, no I meant I used the screw trick not f'ckn foam - in my case I used 1300C high temp mastic.
But yes, there are some foamers out there, mainly bodging builders/board subbies. Couple of big screws or nails right thru' to stop it pushing the board off until its set, then get some skim over it. Saw a Building Control guy actually requesting it on one site "so that smoke and fire does not get thru" unquote.
View attachment 34053Customer wanted solid boarded wall .close as he was getting.
When I rocked up on job bloke had a tiling trowel and wanted to to put dot on solid like I was tiling .Tut tut no continuous bead around tops and bottoms and round boxes... thought you would know better
Dry blocks! Tut tut. Don’t think much of your wetting in brush either!View attachment 34053Customer wanted solid boarded wall .close as he was getting.
Multi brush that . Goes from 2 to 6 inchDry blocks! Tut tut. Don’t think much of your wetting in brush either!![]()
I’ve got to get me one of them!Multi brush that . Goes from 2 to 6 inch
