Has any one 3 coated with this? I have heard people say that it hangs for ever with 2 coat work as it's laced with waterproofer and even heard story's of it sliding down the wall is it really that's bad jobs gona need 3 coats walls are bad .
I used a sample bag of it and it was waterproofed but I think they might do without the water proofer? If not get the second coat as flat as you leaving 6 mm from the surface.
Maybe an accelerator in the top coat might make it go off quicker.
I have used it a fair bit.it will hang forever.you wont get the float on it until 12 at the earliest if on early.
Keep your topcoat as thin as possible as it will crack to hell.i have had it slide down the wall yes the first day we sprayed but looking back we did spray to thick.
When you get used to it its a ok product though.
