Roofer2plasterer
Any known cure for this condition? It's o.k. when i'm skimming or Floating but when i get home it's a constant nagging pain! Bit like the Mrs!
I concur Dr Church!church said:They will only normally give you two injections for the same joint if the pain don't go away then its carpel tunnel surgery , where the ligament in your arm run over the joints in your elbow and wrist they are protected by the carpel tunnel (its like a tube ? the ligament runs through it to protect it from the bone ,the ligament swells up and rubs against the wall of the tunnel causing the pain called tennis elbow, they have cut a slit in the protective tube which allows it to open up and lets the ligament run smooth again ,6/8 weeks off work about £300 if you go private
PhilPlaster said:I concur Dr Church!church said:They will only normally give you two injections for the same joint if the pain don't go away then its carpel tunnel surgery , where the ligament in your arm run over the joints in your elbow and wrist they are protected by the carpel tunnel (its like a tube ? the ligament runs through it to protect it from the bone ,the ligament swells up and rubs against the wall of the tunnel causing the pain called tennis elbow, they have cut a slit in the protective tube which allows it to open up and lets the ligament run smooth again ,6/8 weeks off work about £300 if you go private
grand wizard said:you could put some of that dodo (German word) on it weirdo
dont you mean the hawk was dead on the cement poor thing did bury itHi guys new to the forum, was just looking up a remedy for the good old tennis elbow, which has returned after 20yrs. first got it using k-rend 20 years ago, been doing alot of roughcasting lately,caused by the sand cement being dead on the hawk. Just i read a bit abut what people have tried. The last time i had it i got the injection, worked but it just masks the problem, but i used a elbow brace along side it, so i was lucky then, one bloody sore thing,, anyway https://www.ebay.co.uk/itm/Vulkan-7...t=LH_DefaultDomain_3&var=&hash=item4183c845ca This is the strap you want, all the rest i have tried before are crap.
This strap on (thats what the wife calls it) limits the movement of your wrist. hope it helps anyone.
I find not working as hard helps try just 2 days a week its a mugs game this plastering malarkey!!
