Spraying skim
dai dog
Sprayed my first room yesterday to have an outing with the ritmo, the water was set at 80lpm, which was way too wet, so decided to give it all a second pass after turning the water down a little & turning the speed from 7 to 8, the water must have been around 65 I guess wich I still think was a bit too wet! The water bottle is the mortar one which only goes down to 75 so I was lower than any increments! Would you put the smaller water bottle back on to accurately adjust the flow for skimming? Also Ian jones was right in saying that the whole lot would go off around the same time because it's all on the walls so quickly, (was hoping for more of a rolling set!) so we were rushing around a bit! I know there's a bit of controversy in putting multi through a machine, but do the others like mp & spray finish go off differently? One thing I will say is, if we had a good thickness on, it would have come up lovely, it was like troweling silk, I'm putting that down to the fact it's been through the r&s!?
if it could be changed quickly i would use the ditty bottle.
the thistle stuff goes slower not sure bout mp finish
