goody
Anybody had any problems spraying ecorend. Having trouble with it. Machine seems to spray it fine for a bit then sort goes thick, thin and labours the machine. Quicker than a worn rotor and stator, up and down every 5-10 seconds. If we detach the hose and clean hopper out into tub, then reconnect everything is fine for a bit(5 odd metres or so) then same thing happens again. Any ideas chaps. Is this stuff a bit like krend to spray? Oh and water setting on the xl is up at 600, any lower and its too stiff to rule(pressure is 1 bar to 1m at this setting) so I know were not far off but somethings amiss ???
