1. Want to see how the new TPF works? Click here or you can drop me an email danny@plasterersforum.com
    Dismiss Notice
  2. The Plasterers Forum has now made it even easier to share photos and videos than ever before Click Here To Learn How
    Dismiss Notice
  3. TPF is the biggest plastering community and resource on internet... we are still growing.... we are nearly 10 years old so we are here for a long time yet...
    Dismiss Notice
  4. The Plasterers Forum is growing but we need your help to keep it growing.... Introduce yourself and say hello get involved... they dont bite :-)
    Dismiss Notice
  5. The Plasterers Forum is very busy!! ...25% up on last year!! Be a part of the biggest plastering community
    Dismiss Notice
  6. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
    Dismiss Notice
Spraying basecoat
Discussion in 'General Machine Discussions' started by Jim85, Apr 29, 2017.
  1. Jim85
    Jim85 Active Member
    I don't normally spray basecoat but had a bash at it today as I was on my own. It was hpx it went thru the machine fine but it wasn't coming out of the gun very well. I tried moving the air backwards and forwards but it didn't change it much. I think I had the gear a bit stiff but what size nozzle should I be using with basecoats? We normally just stick with a 14 for render.
  2. jamie01
    jamie01 New Member
    12-14mm maybe if it was abit stiff wet it up abit machine may have been struggling
  3. Jim85
    Jim85 Active Member
    Yep I think I'll try it again on next job and wet it up a bit more. Thanks
  4. Weberwizard
    Weberwizard Member
    Try it with plastersiser in the water it makes it very nice to use saves wetting it up and making it drippy
    • Like Like x 1
  5. Jim85
    Jim85 Active Member
    Rite iv had a few goes at it and it's definitely better then troweling it on. Iv made it wetter and it's a lot better to spray but how do I get it to spray more of an open fan so it stops slumping down the wall before I get a chance to put a trowel over it. Will a bigger spray cap do this? I'm using a 12mm at the moment with the air set back 12mm
  6. Rigsby
    Rigsby Private Member
    Thought of using a texture gun? If its only thin then an 8 or 10mm cap.
    I have sprayed Kilsaren Super Coat which is a bit like Rend aid. 10mm cap and hold the gun further away from the wall. Wetter than hand apply as well. 60m2 an hour no problem.
  7. Jim85
    Jim85 Active Member
    Never used one john. Does it spread the gear a lot more?
  8. Jim85
    Jim85 Active Member
    We are meshing as we go aswell so that slows us down a bit and it's making more mess then I'd like but it's better then carrying all that shite up the scaffold and it's saving wear and tear on the spreading arms!
  9. theclemo
    theclemo Private Member
    John is that there super bond render. I have to spray it this week. Do u remember the water settings for the ritmo.
  10. Rigsby
    No I dont, it was two summers ago. Sprayed ok though.
  11. PFTwales
    PFTwales Private Member
    what machine and rotor stator you using Jim
  12. Jim85
    Jim85 Active Member
    K4 d6-3
  13. PFTwales
    Ok. i guessing you are doing a thin base coat so maybe you could try a slower rotor and stator with an 8mm cap. the slower speed will certainly control the waste and mess and will spread thinner.
    If it a total 6mm base coat i would use a d 3-4 6 ltr 8mm cap ( spray a quick light 4mm pass. spread it with a serrated spatula.then bed the mesh in lightly. leave it set and lay a second really tight pass by hand over the lot) if its a reinforced 10-12mm base id use a d 4-3 12 lt 10mm cap ( spray a 6mm pass sames as monocouche in bands .bed mesh in. spray a 2nd coat over this and leave to set before scraping flat.)
    that should make a good difference
    • Useful Useful x 1
  14. Jim85
    Jim85 Active Member
    Awesome thanks for the info. Iv got a slower r n s in the van I'll give it a go. Think it's a 9ltr one.
    • Like Like x 1
  15. Orangemachineman
    Orangemachineman Well-Known Member
    We spray our basecoats all the time now
    Spray as wet as possibly
    1 guy spray and another using a serrated edge behind then drop back and mesh together
    Spraying for around a hour can get you 50-60m2 on no problem
  16. Rigsby
Share This Page
