Solid wall damp proofing
Kundu99
Hey all need some suggestions found damp in my interior walls.
Tore them down today they are stones
What will be the best option
Dry rods or Membrane
Also should it be lime plaster that I must use ?
I have attached a few photos for reference, i have also found a crack in between the stones how can i fix that ?
No damp visited your property .
You have a badly tied in abutment wall
Need straps of sort ..
Lime.
Tie crack
Mesh
Lime
Check other side of wall where the crack is, moisture ingress there.
