Ritmo l breaching problem
Demon
Hi I’ve had a ritmo l For six years always run well but I’ve had a problem recently with powder not mixing properly rotor and Stater are fine recently added a daughte for six years always run well but I’ve had a problem recently with powder not mixing properly rotor and Stater are fine recently added a doser To run flakes through now somebody says it’s breaching can’t seem to fix the problem powders coming through wet on the outside side through the middle any ideas
@theclemo
Hes the oracle on ritmo’s
Have you kept up with welding the spot that wears down on the outlet at the bottom of the mixing chamber
