Rimto
Putzmiester
Alright lads
need to get a second pump and am thinking of a little rimto any advice on which one to get,how long do the sators last,can it handle mono ok it's only a second pump so I know it won't do what my g4 will do but around 30-40 m2 here and there,
any thoughts lads.
Mainly use ours for mono and ocr, it pumps fine, I've got 12 pallets of Blanc du Literal out of a non clamp r/s, pumping it 12m high in some instances I should add.
You should part x ur M wezly. Its the right thing to do
Is it a quicker output? Whats the difference between them?
I thought the 230v G4 was the way to go, until yesterday of course when we all found out your nobody without a pair of sp11's.
If you would be satisfied with a D4-3 on your G4 then a Ritmo L is the way to go.
Mine is a 240v which I bought because there is less chance of tripping (apparently) over the 110v. Something to do with amps.
it is so easy to move around, spits into 3 parts and each one can be handled by 1 person. Even the whole unit can be moved by 1 person but mine has to go up two battens onto the back of my truck so just a bit heavy on a steep incline so I take the motor off.
No difference in output. It will do the same as ur M. The L has a vibration unit which is great for emptying the hopper without thumpin it and the 2.2 kw motor will pump further which i have needed a few times on some jobs.
If the material is good quality you will get 20 mts material hose on the Ritmo M. say for instance you have 15 mts on and its pumping fine at 10-12 bar then it will take another 5 mts.
The L is supplied with a 15 and a 5 mt hose
Thanks everyone for your advice,I've seen the one on ebay just a bit soon after Xmas prob looking around April-May would go to stu at ukplastering machines as he's my local dealer
and always a safe but I was just looking for a few different views which you have all give me cheers guys
