It's called side light. We have it bad over here in [emoji1037]
Welcome Aussiejoe, where in Oz are you?
I've honestly never seen absolutely flawless render with glancing sunlight across. Most look s**t hot 99% of the day until that sunlight is directly across the wall even if you put a straight edge up and you can't see any gaps behind it you can guarantee the sun will still show it up, Happens with facing brick, glass, gyproc, new car paint - sun magnifies every slight imperfection making it look 10x worse than it is when it's at the right angle.i like to use the sun as a test. Thin coat can look absolutely flawless with the sun side on. Not always the case but its good when it is
Theres something about the small aggregate in thin coat that hides slightly uneven base coats. I'm not blowing smoke up my own arse its a fact. @Orangemachineman @Dansouthcoast84 will back me up it can look absolutely flawless.I've honestly never seen absolutely flawless render with glancing sunlight across. Most look s**t hot 99% of the day until that sunlight is directly across the wall even if you put a straight edge up and you can't see any gaps behind it you can guarantee the sun will still show it up, Happens with facing brick, glass, gyproc, new car paint - sun magnifies every slight imperfection making it look 10x worse than it is when it's at the right angle.
Fair enough mate. You're a full time renderer youve got a lot more experience than me. I see it as flawless maybe others don't :-/I'm not doubting you mate I've personally just never seen it. I've seen so much work that looks amazing until that 20-30 minute window when the sun is acutely across it - whether it be dry dash - mono - thincoat on board systems or traditional float finish I've never seen perfection in tough lighting conditions.
@Olican wasn't it you that said a while back about some guys you worked with who were doing k-rend since it was out and still got shadows with sun across?
Ahhhh bless the creators of woodchip.I find its the flat finishes that highlight the shadows more. Render such as pebble dash/roughcast tend to disguise it better
anyway on a more interesting subject I've been paid out on the insurance and got a Santa Cruz Nomad C. She's a beaut. Fox Talas 36, RP23 shock both kashima. XO groupset, Hope m4 brakes. Can't wait to get it out!!!
Time I've shagged about doing a days plastering malarkey, I'm too shagged to get out on a pushbike!!
Think I'm gonna let work slow,down and get me one of those, and get fitter!
Crackin bike mate what did you replace it with?You will enjoy this I've had one pretty much the same spec but xx1, I miss it like hell
That's a shame. Get another bike and give it a go again.I stopped riding mate I miss it very much as I've had
A lot of bikes from when I was a child I raced xc. I also climb for a hobby and only get so much time .
Indoor climbing or the real deal? Done a bit of indoor. Enjoy it a lot but never seem to keep it up. Bloody hard though
Why does render look bad at certain times of the day when the sun is on it
Cheers Dan, Cheers Noel.Theres something about the small aggregate in thin coat that hides slightly uneven base coats. I'm not blowing smoke up my own arse its a fact. @Orangemachineman @Dansouthcoast84 will back me up it can look absolutely flawless.
