Rendering back and sides.
FreeD
Got a job coming up where the render is blown on the rear all the way to the edge on the rear elevation...the side elevation is not bad...customer may try to save money and just get the rear done for now...how do i finish at corner with side? remove the render from from the back and about 300mm onto the side elevation? then bead and patch in on side elevation?
Yeah that sounds right, ,but what is the finish? plus you may get a scar for the join, but it is always best to let the customer to know what might happen and tell them the only way not to get a scar would be to redo the lot unless you could run a angle grinder down the corner and try to work to that.
yea informed the customer that there may be a scar on side elevation...told them its a patch and not recommended better to do the lot...thank m8
tell them its solid 300mm back from the bead and theres no need to hack it off every other coont does ;D
