Ive used it loads Craig scratch your first coat on quite thick then have all your mesh cut ready bed it in but don't over lap trowel it in tight then leave about 15mins then another coat over the top mate but make sure you cover it well stop the mesh grinning throughHas anyone used this, got a few walls in a spare room at home that ideally I don't want to knock off but they have loads of tiny hairline cracks, the plaster itself is pretty solid but as I said just has hairline cracks.
don't need to DanI think it would work well.... but bed it into bonding first...
yep if your gritting the walls it might be best couple of shovel full of bonding in your first coat just to cover over the gritCheers, may blue grit the walls 1st just to give it a better hold with the extra weight
You on drugs ??I think it would work well.... but bed it into bonding first...
You on drugs ??
They didn’t sound that bad thoIf the walls are that screwed I would often coat them up with a tight coat of binding first....
