church said:Looks alright to me looks like the joints are hard to get a fix in that will not help you sometimes you have to drill and plug the drip beads and somtimes its easier to stick the angle beads in the scratch coat all substrates are different and you have to adapted your bead fixing to make life less hardwork , but its good to learn nailing them also
spunky said:if you need to stick them up use dab adhesive and w/proofer in both coats ;D...........fitting bellcasts is a two man job really try and ask for a hand if poss mate
church said:Just bang a galv nail in the plug red plugs work well with a 8mm drill bit
could you not stick em on with expanding foam? what do you think?bodplasterer said:I have worked on a job where some one used gaffa tape and i have also seen some one put up beads with multi.
