what are you talking about ? you cant use parinter as part of an ewi system, its not an adhesive, its a prep bonding coat for acrylics, that will be why you cant find it out.
I just want to cover the old painted render with parinter and wanted to know how many pins per meter do parex spec if needed just for peace of mind.:RpS_confused:still not sure what you / client actually want to put in the painted render....? and why pin it ?
Sorry Jrend - posted at the same time there... aimed that at clever clogs Danny.....
Pinning the mesh - OK....
someone will be able to help - or get in touch with Parex.....
Just read this mate and thought it would better to be safe than sorry.
6. Adhesion
If any of the previous tests 1- 5 did not
work DO NOT carry out this test as
incompatible surfaces can not receive
PARINTER RENOVATION without the use of
pinning a full layer of TV10 reinforcement
mesh and installing mechanical anchors
through the mesh across the whole façade
to a Parex specification.
you must be loaded buying parex
Wish i was a quid behind you mate.
its just parex covering there arses, weve done getting on for 40 projects using parinter and not once pinned it.
give one of there reps a buzz.
