??? ??? ??? ???pwi said:Does the mesh require fixing
its not often i agree with this person but he is correct... ??? To££a but correct.... but dont spray thincoat what ever he says as he is just a salesman and will sell your granny a kirky vaccum cleaner when in a nursing homesimplybesty said:lay a thin coat over the boards about 2mm, bed the mesh into it , then lay a second coat over the mesh nice and flat job done
grand wizard said:no spurs won you little c**t and you should be able to get the basecoat flat without a waffle float and rich if the gear was going off that quick you should,nt be putting it on the wall now fcuk off simps
grand wizard said:ok rich i just like getting on simp,s tits
Render Systems said:its not often i agree with this person but he is correct... ??? To££a but correct.... but dont spray thincoat what ever he says as he is just a salesman and will sell your granny a kirky vaccum cleaner when in a nursing homesimplybesty said:lay a thin coat over the boards about 2mm, bed the mesh into it , then lay a second coat over the mesh nice and flat job done
no probs using a waffle on thin coats but be very careful you dont catch mesh , can cause you a real nightmarepwi said:Do you use one of those tools to go over bottom coat to remove high spots , and what gauge of mesh should it be
