Can anyone recommend an equivalent product available in the US to Sika's Casco WallCraft / WallCraft RDF / Schonox RDF?
Here's the product data sheet:
Description:
WHITE CEMENT BASED LEVELLING COMPOUND. WORKS JUST AS WELL ON TILED SURFACES AS ON OTHER INDOOR WALLS. POSSIBLE TO LEVEL AND SAND IN THE SAME DAY. ON MOST SUBSTRATES, NO PRIMER IS NEEDED.
Casco WallCraft is a white resin modified cement based levelling compound. Casco WallCraft is an elastic and rollable levelling compound that works just as well on tiled surfaces as on other indoor walls. Thanks to the fast drying time it is possible to both level and sand the same day. On most substrates, for example tiles, no primer is needed. Casco WallCraft is characterized by a very good grindability and a brilliant white finnish. Casco WallCraft can be coated with paint or tiles.
Description:
