Is this angle bead suitable for skimming...
trowelhead
This is my first post on this forum :)
Was wondering if this angle bead is suitable for 3-4mm of plaster skimming? Are the wings a little too short?
I'm in France and it's the only type of bead that I can get locally.
Any help would be greatly appreciated. Cheers.
well it's a angle bead would be used for rendering . If needs must you will need to put skim on a bit thicker . Just make sure your bead is well tight to surface your skimming onto.
thats looks like a render bead (they are expensive to 6-7 euros in brico depot)
i have not seen any skim beads in france ---
-i bring from uk..
pic below of what you need.......
Hello TrowelHead
Welcome to the forum
Like the others have said it looks to me its a render bead
Danny
Its render bead mate not good enough for skim, look a bit further a field for plastic bead for skimming it is available
thats a rough bead mate, when i worked in france i had to take all my own stuff over. no finish at all just that white one coat shite.
if you do have to use it,just build it out with skim 1st,skim your alternates,then skim ya window/angle walls
I've just bought a sponge float after reading lots of good stuff on it. Looking forward to giving it a try, especially since the plaster I'm using - Lutece 2000L - goes off pretty quickly before you get a chance to flatten it properly. My weapon so far has been the spray bottle.
You can get skim beads from Brico Depot about €2.40
Corniere-d-Angle-Metal 2.5m
Bit pricey but if needs must.
