Ewi 225
smarts
Has any 1 used ewi 225 base coat straight onto brick /block iv been told it is applied 6mm with mesh embedded just checking is 6 mm OK
Gonna top with silicon thin coat
Newer used the ewi system only used ecorend or Johnstones and they both state 10mm thick
Just seeing if any done 6mm thickness cheers
6mm is fine, the only time you may get a problem is if the bricky has f**k*d the mortar mix, or there's not uniform suction across the span
I've found both 225 and hp12 are fine at this thickness with mesh.
Cheers been told to put primer on 1st so should even out suction
