Everbuild accelerator with fassacouche m200
BigBish
Ok so after sagging it off. I've been given a couple weeks of fassacouche work.
I seriously don't want to leave it on the wall overnight at this time of year.
It has to be this stuff as the contractors paying.
Also will it f**k my machine up? Or can I just flush it through after ?
Thanks for any help
For me I use accelerator but always flush the machine out off the mains tap after cleaning out. On my Ritmo, I take off the mixing shaft and the pipe to the mixing zone. Wack the water up on the bottle and run for a few minutes. Drain off.
Fassa is a low cement high lime content so unless you put loads in, accelerator doesn’t have much affect.
Nah shouldn't effect it as rigsby said, I've never had any issues. although My issue would be using another manufacturer of accelerator, do fassa not make one? As any issues with the render, fassacouche won't want to know.
Wickes has always worked but that brown ingredient that stops corrosion can leave a sticky reidue. Cost me mega bucks a few years ago but I didn’t flush out and drained off leaving it to dry out on the sensitive water solenoids and more.
Only use it on hand apply now, moved on to ordinary no gimmicks Calcium Chloride.
