mark ross
Challenge mark. mmmm Not your every day bit of rendering .http://www.plasterersforum.com/attachment.php?attachmentid=1532&d=1350836003
What you putting onto it Mark?
Nice little advert for Knauf I would say.Do I get discount ??
Could you not rub up rend aid over the aquapanel
Be good to show off its' capabilities :RpS_thumbup:
Have fun Mark :RpS_biggrin:
Hell of a challenge to get a finish on that though...... especially over the top of a front door!
Good luck Mark - post some pictures!
I don't think there's any luck involved with Mark. Definitely one of, if not the best tradesmen on here.
First a Shower..... now a board discount! LOL
I'm off on a week's Holiday this week (getting a new heater system installed) but will contact you when I'm back.........
I really like the application Mark - it will deifinately show off the ability of curving the Knauf Aquapanel Exterior!
Cut the board into 300 mm strips and then crack the core to get it flexible (in 300mm strips it will go to a 1 mtr rad - no problems. full 900mm wide board will probably break with such a tight radius, 900mm of to 3 mtr rad).......... don't score the board, cracking the core is all that is needed. Over stress the mesh, or scoring the mesh will make it break.
Get plenty of piccies - if you have any problems message me on here and I will get in touch.
tic tic tic tic tic................. BOOM!!! LOL:RpS_scared:
Cheers Marra - just want everyone to be confident using Knauf Aquapanel Exterior and make sure no-one has any problems. Most sites have enough problems - without a product making it worse!
whats the best way to fix your boards to steel?
i have some steel vertical pillars to do with a thin coat system
might be devils advocate here, and theres nothing wrong with aqua boards,dont get me wrong
but the last one of these i did was using the gtec external plasterboard which id say is more suitable due to its lightweight and fixing capabilities
its structual steel, its some pillars in between some large windows we are using your boards on the job.
we cant fix any type of subframe to the girders as there isnt the scope around it, due to the windows already in place.
Can't win on here, if you slagg someone off you're a nasty ******* and if you give credit where due you're an arse licker.
There are some absolutely useless T***s on here, actually I think there are loads and loads of them, top guys like Mark and Paul to name just two, well they're bloody rare creatures and without them this forum wouldn't be worth a toss.
If that makes me an arse licker......well I can live with it.
