I have a carbon trowel coming soon
I don't have one but thinking of it,you can do somthing to them to stop from rusting can't you?blacken it or somthing along them lines please advise anyone???
SoundUse them daily, you don't have to do anything with them.
I'm breaking a nela carbon in at the moment. Been using it regular, keeping it clean and it still hasn't changed colour yet. The marshalltowns would have gone dark by now. These must be a different grade or make up of steel.
Which make would that be?
Great stuff matethat is correct I will be showing how to do it sooon If I can remember Trowel is not here yet though
Fair enough it might not need doing but it looks coolGreat stuff mate
Educate me pleasethat is correct I will be showing how to do it sooon If I can remember Trowel is not here yet though
There's been a few threads about it, it's called a forced patina soak the trowel in vinegar and coke I believe.Educate me please
Don't ye wish they would sort the f;#*"€by handles out so they wouldn't keep cracking off these bucketsView attachment 18714 I got one mt one the other week great trowel
The bucket came as seen solid bucket collomix oneDon't ye wish they would sort the f;#*"€by handles out so they wouldn't keep cracking off these buckets
Should make a nice Ornament MtI have a carbon trowel coming soon
Lol, you can come have a day with me if you fancy.
To remove rust i leave metal for 24 hours in vinegar. Never heard of coke for rust but I guess it will work? Put the metal in a bag and add some vinegar then move it about every few hours. Only need enough to coat everything so half a cup is plenty. Guess the blade will puncture bag so go carefullyI.ve got the Nela carbon but it's got little black spots on all ready. How long do you leave it in the coke and vinegar and how often
White or brown vinegarTo remove rust i leave metal for 24 hours in vinegar. Never heard of coke for rust but I guess it will work? Put the metal in a bag and add some vinegar then move it about every few hours. Only need enough to coat everything so half a cup is plenty. Guess the blade will puncture bag so go carefully
Either white or brown. You can also go to shops that sell citric acid in crystal form and just add water. Wilkinsons sell citric acid in the home brew section in small pots. I used the brown stuff on a masonry drill I found on my drive. It was covered in rust so got a small amount of brown vinegar in a freezer bag, put drill in and 24 hours later it was shiny and clean.White or brown vinegar
How often do you need to do itEither white or brown. You can also go to shops that sell citric acid in crystal form and just add water. Wilkinsons sell citric acid in the home brew section in small pots. I used the brown stuff on a masonry drill I found on my drive. It was covered in rust so got a small amount of brown vinegar in a freezer bag, put drill in and 24 hours later it was shiny and clean.
I only do it to remove rust from metal. If you oil trowel every day it will be fine. You would need to leave trowel un oiled and wet for more than a week for the rust to be bad enough to need treating. Bit of wire wool dose the trick if you forget to oil for a few daysHow often do you need to do it
You can use the citric acid to slow your set down aswellEither white or brown. You can also go to shops that sell citric acid in crystal form and just add water. Wilkinsons sell citric acid in the home brew section in small pots. I used the brown stuff on a masonry drill I found on my drive. It was covered in rust so got a small amount of brown vinegar in a freezer bag, put drill in and 24 hours later it was shiny and clean.
Handful of board adhesive does sameYou can use the citric acid to slow your set down aswell
Cream of tarta from tesco. Pack of 6. One of them in a bucket will slow the set time downHandful of board adhesive does same
