What's the best way to prime thermolite blocks before K-rend Base coat and mesh, cheers
G GARZX9R New Member Feb 26, 2017 #1 What's the best way to prime thermolite blocks before K-rend Base coat and mesh, cheers
Orangemachineman Well-Known Member Feb 26, 2017 #2 Phone them I would and get a spec then follow it Easy with parex as it's micro then render away!! Sent from my iPhone using Tapatalk
J Jim85 Active Member Feb 26, 2017 #3 Hpx and full mesh with extra mesh on stress points is the spec iv got for light weight block Sent from my iPhone using Tapatalk
Orangemachineman Well-Known Member Feb 26, 2017 #7 GARZX9R said: SBR,What ratio or just neat Click to expand... Follow the spec You've got good advice from a k rend user!! Sent from my iPhone using Tapata
Orangemachineman Well-Known Member Feb 26, 2017 #10 Jimbob9 said: R10 and K1. Mesh in first pass. Or HPX, mesh and K1. Click to expand... Liked Sent from my iPhone using Tapatalk
C craigEEE Active Member Feb 26, 2017 #11 We got told by K-rend we could do 2 coats of r10 and go straight onto block, we decided to hpx the whole lot and used sbr as a primer
F FlashFloat New Member Jul 8, 2020 #12 What would the best sand and cement mix, for light weight blocks? Sbr the walls (pre soak or not?) 5-1-1 plastering sand, cement, lime, scratch coat with mesh. then a 6-1-1- Top coat or same again (5-1-1)? Water proofer and lime in both?
