best way to attach angle bead?
platinum
whats the best way to attach angle beads???? i've been using an instant grab adhsive whats to best way??
do u mean mesh angle beads or thin coat skim beads
i usually use whatever material im goin to be using to stick the beads with unless its skim beads onto plasterbord then i staple them
anything you want mate, long as it doesnt hinder you in any way..
i usually skim unbeaded areas first set and bead up with scrape out of the bucket.. ready for second set..
end of the day, its not exactly reinforcing as such, the plaster holds em rigid once its set..
u must be making a fortune being able to afford gripfill to stick your beads on :eek: or stealin it from the joiners ;D
'gripfil' or 'my mums own brand no nails' same sh't innit :)
incidentally...
15 people found stuck to the wall at heathrow...
police believe irish muslims let off the worlds first 'no more nails' bomb
