Acceleration
Demon
hi lads using Webber pral m any one scratching off the next day yet and gcan anyone let me know of an exelerant that doesn't damage my ritmo l cheers
Weber should be ok for same day??
MOST accellorators will damage some of the wanter components if you use them regularly
maybe try a retarder instead as you use far less of this in comparison.
Ive seen a solution where a seperate running adapted water pump will actually add the required dose of accelorator direct to ur mixing pot and bypassing the main water flowing system of the machine
I tried one last November on a cupful to a 330ltr barrel.
Took 3 days to go off.
Thanks can you let me know where I can get some retarder I'm in Lancashire
