Wrinkled finish?
Yeah we've worked over similar. One job I got so pissed off with having to trim the foam off myself that I told them "any more and I'll just work round it, you've been warned". They were warned @John j @algeeman
Your wrong @essexandy
Look at proper 2 coat work around a socket and you will see 2 different separate layers if fresh 2nd applied.
Look at 2 coats from same mix and it will be 1 layer of material exactly same as 1 coating.
I've had the chance to see my two coat work 'cut through' on several occasions and have never been able to see the two separate layers.
I can always always see 2 separate layers if fresh 2nd coat but never ever if 2 from same mix hence why I believe it to be no better than 1 coat.
Sometimes needed
I have when f**k*d it up. Did it the other week on my house trying to be a clever c**t instead of putting a tight coat of bonding on and hoping to go from plasterboard to hardwall and levelling up in a cold house.
Admitted defeat and scratched it up and skimmed it next day.
No shame in that pal it's called having some pride!
@John I does it all the time after I snag him.
Well, always remember what you told me a few years back...get your ceiling angles straight and you could hide a dead body in the walls!! Cheap valentines day!
