Which plaster?
Monkeysuncle
Evening
What’s the best way of plastering inside of exterior wall of house, standard brick with cavity? There’s not enough room to batten and board and I’ve been told dot dab is no, no in this scenario.
Is browning or hardwall ok for this application, skimming with multi finish?
Ta
I’ve no idea why you’ve been told dot & dab is a no no! Nothing wrong with it or with float & set using hardwall. All depends on what you want.
Evening
Ta
Yes
Evening
Ta
See the fella who advised you so far?
Ask him to keep advising you
Evening
Ta
Uncle
Monkey Hug GIF
Cavity? Need to find out if it has one...
Safe bet is insulated plasterboard stuck on with foam.
