What size scrapper best
brad123
hello forum,
What size mm scrapper
Do you think works best for monocouche for same day scrape and next day scrape.
Lost my lovely worn in one and can't remember what size tooth it was.
Ok cheers lads, best way to wear it in abit, someone said about scrapping it along floor to take the sharpness off
I love this I'm learning more. I always used the short tooth scrapers not scrappers lol never had a problem?
Here's a selection :sisi:
Short are sharper Greg , which is better when the mono is as hard as concrete , next day
Short for everyrhin. You rub your set at tye right time u will never need a long tooth except for hirting the labby or scratching your arse with
What's the difference between sharp tooth and twist tooth ??
The little v shape press ones with a blue handle are sh1te. If your not bang on with circular motion. Thay can leave lines in it.
The twist shape spike are the best Les sells em.
i use the sharp tooth ones
i guess the twisted ones would last longer because the edger would be thin and scrape easier for longer but just guessing
hello forum,
I find this one is best. Leaves a nice clean job
