What bead thickness for hp12
Ashleyscoob
Got a k rend thin coat to do on new block work not sure what bead thickness I can get away with would 6 mm be ok,I am going to mesh and render with hp12 then prime then thin coat
Block work is pretty flat
10mm if you want to keep the reps happy. You'd have been better with uf base maybe, unless it's lightweight block then you'd need hpx.
