Weber m1
claremont
Morning,
We are currently doing a job 200m2 on eps using Weber m1 but we also have a wall on cement board 6m x 2m high to do.
I know Your not supposed to use mono on board and thin coat would be the spec but that does look a different finish.
I was wondering as the m1 can go on at 10mm would I be able to base coat and finish the same as the rest of the job.?
Your thoughts would be appreciated.
Thanks.
Morning,
Thanks.
the product it’s very specific so ask Webber rep pal
M1 is there lightweight version of pral m so it's fine to go on a carrier board, just use there adhesive first, as you would on the eps.
Thanks guys
Yeah I have completed most of the job straight on eps with the m1
And have base coated and meshed the carrier board.
