Webber xp
Ianspreader
Hello just wondering if any of you guys has pumped webber xp through a ritmo m before and how it went cheers ian
Its m1 then. Xp is the name of webers insulated system either using lac with texture finish or m1 so one product only will be m1 (that's what it was last time I checked) its mineral like mono. Will be polymer modified tho and probably lighter. Should spray similar to mono.
Were installing xp at the most but LAC followed by weber sil
I must correct that looks like weber have had a freshen up
Xp system looks like its only the m1 product i used to know it as the lac system where m1 was just m1. Looks like LAC and sil is called xm system now.
We sprayed it through a monojet. It sprayed ok but was crap to derby and flatten.Make sure you mask up well too cos its a bugger to clean off the day after.
