oasis said:been to see a small job 2 day. guy has boarded out his small coni and has put wba all over the boards and even scrimed up, Mr DIY did well. bit pointless still ganna have 2 PVA it to seal it as its been there weeks
oasis said:ok i see, mind you from now i when i use wba or bond it i give walls a week pva first then apply
essexandy said:oasis said:ok i see, mind you from now i when i use wba or bond it i give walls a week pva first then apply
This might not be the greatest idea as then you are relying on the bond between the PVA and the background which if it's suitable why would you be using the WBA in the first place?
