Ventec board
church
HI all , i need to dub out ventec board prior to sto base coat and top coat , what products can be use please, i need about 6mm thickness , thanks .
church
cant you just use aramat classic to doit?
STO have sent the wrong beads , there customer service was not good ,it would double the cost to dub out with armat , i knew very little about there system tbh , they sent 10mm drips and 6mm stops . They then said the total thickness was only 4mm for both coats . So every thing was set up wrong before we knew .
Dansouthcoast84
cant you just change beads then?
6mm stops and mesh anglebeads?
sto are shite
themucky1
If they’ve sent out wrong items then the cost should be on them to return and replace the wrong items. Fcuk dubbing out with classic to 10mm it would bankrupt the job lol
Runswithscissors
The builder wants to use k rend uf base , as there have some over from another job .
Check with STO, but their board is not a cement based board and will have issues if you use a cement based render on it…. (from memory, their board is a glass and epoxy board, and their renders specifically for the board are all acrylic / mineral based….)
If they sent the wrong beads, surely they should accept some responsibility…?
