Van
MIXERMAN
Done this in last couple of vans .keeps the rest of van tidy,
Someone asked wot the box in rear of van was for.
And the bungee strap rubs against paper sack, skim everywhere, also stacking bags up like that has to throw the driving Balance out with the weight.
Another 2 bags on that side and a sweet corner turn and your going arse over tit
You're talking out of your arses as usual, the only thing that rubs my sack away ,is when I've got my g string on . I'm 25stone so it keeps the van level. You gays are so bitchy.
Ignore them, that's a very nice set up, tried and tested, with the essential technical roof batten.
I use something similar to hold my sheet metal in place against the side.
I'm just trying out using a bit of plank/board to hold em back with a shorter bungee or strap across the top
What do you use to cut out for vitreous
5" angle grinder, tight'ish octagonal hole covered by top hat adaptor flange, or, small size debris collar (inverted storm collar). Ditto or jig saw with ceramic blade for cement board. Not so keen on the debris collar as I think it might collect soot and ignite, but does look ok.
