Utiform quattro for sale
I suppose I'm asking, what does 'base coats' cover? Ocr obviously, hardwall? What about s&c? Or is there even a machine that will spray s&c?
A diesel machine will spray s&c but u need the right sand. If you want to spray everything you would need 2 machines diesel and electric unfortunately
I'd quite like to buy a second hand one.
But at present it would have to do s&c, monocouche.
Come someone give me an ideas of makes & models to look out for?
Cheers Bobby, I was thinking if the s&c was premixed? Is this not an option? And would the sharpness or coarseness of sand be an issue?
Does the sand need to be at the finer end? Premixed?
It would mix the monocouche I presume
I have put s&c through my ritmo but the mix needs to be spot on with the right sand and additives.
Either buy a machine that's can spray without issues or just use CPI or weber OCR.
Did you make the video bobby of the ritmo doing s&c.
