Hi all. I'm after some advice on a simple job that is turning out not to be so simple. In a nutshell, I have a wall in a basement flat that needs skimming and I plan to do it (I'm a DIY plasterer). The current surface is mostly bare render with a small area of old skim around the window. In terms of surface, it's a mixture of silk paint over some of the skim, bare skim and bare render (at least two different types). The paint on the skim won't budge. There was also paint directly onto the render, which has peeled off in sheets, leaving a very dusty surface. In order to prep it for skimming, I'm thinking SBR over the render as it is very porous and is an external wall, followed by some kind of bonding agent / blue grit over the lot. Then skim. Is this right and should I use PVA at any point as well? Cheers
