Can you use e.m.l with Ocr I've used it with sand and cement render loads of times and used it with webber once with no problems but I have it in my head that your not supposed to.
It was under cover so used some galv i had knockin about, and ye i did scratch coat it first, with some parex and sbr mix, interestin lttle job , i will put some pics up later, cos i did some wallcrete with it , looks mint
I just used OCR over a board with building paper on it over a lintel. I EML'd the foker with a good overlap based out then fibre meshed it too, then give it a comb, after the scratch coat had dried oot I give it a another I topped it out:RpS_thumbup:
