Tyrolean substitute
user_removed
Ordered some tyro from SI and they have sent wrong colour, was wondering if anyone had tried running pissy mono through.
doing a full area, not patching.
also the cullamix tyro is £23 per bag
User___removed
Mono is more brittle than s&c so I'm not to sure.blones laided a tight pass of mono on first then a heavy scat coat on top.i personally don't think mono will take to s&c with a tyro gun.i could be wrong.i have often thought about doing it as tyro pre bagged is very expensive.
user_removed
I have based out with ocr I think I'm going to go over it with the cullamix and stick to what it says on bag, cheers lads
user_removed
No bobby, it's already on it's just the front of a garage which is attached to a house, all white tyrolean.
iv patched it up (only 2/3 m2) but I will flick the whole of the garage front to try and blend it in as best I can.
the only problem is, the garage will look new, the rest of the house will look grotty and weathered, but it's an insurance job and I'm doing more than I should be.
