plasterjfe
anyone done any tyrolean proper with a compressor and spray hopper rather than a flicker box
sprayit said:Yes mate do it all the time. The video i posted here shows a texture finish (tyrolean). The finish is often touched up by a hopper gun and compressor. You need a big compressor and the materials you use will give you different textures. Wet, dry more air less air.
There are products like the mineral render i use or u can use mono or even tyrolean (pricey)
The hopper is quicker than hand but a pain in the arse if you have restricted access because you cant maintain the same distance and angle from the wall
sprayit said:most companies deliver next day
sprayit said:refina do hire. what are you looking to hire
