so always trowel up and down and keep it that way through the whole set will help?
Sponge it![]()
To prevent tiger striping you should get your first coat on tight and flat then lay in with fresh stuff and first trowel no water and even pressure
Thats f**k*d his pension up then hasnt it!??Tiger Stripes, the biggest mystery to haunt Thistle in the last 20 years. We have had gangs who have left decent work for years suddenly get tiger stripes everywhere, usually when they get a new trowel or the seasonal mix of the plaster changes. The best ways to prevent it are a) don't one coat, b) use less water, c) trowel with less edge and at a slightly different time.
It is caused by poor milling of the gypsum but BG will never admit that. I got told this unofficially by the man who actually invented Multi Finish who is now retired and has his pension paid by BG and of course will deny everything. Basically the "fines" in the gypsum don't break down correctly and cause the surface to appear streaky or tiger striped.
Amazing amount of knowledge on here...i was just trying to remember when multi was invented and released..maybe he told you that as well?Tiger Stripes, the biggest mystery to haunt Thistle in the last 20 years. We have had gangs who have left decent work for years suddenly get tiger stripes everywhere, usually when they get a new trowel or the seasonal mix of the plaster changes. The best ways to prevent it are a) don't one coat, b) use less water, c) trowel with less edge and at a slightly different time.
Mate this post is about tigers and red stripe beer you can start a new thread.It's all in the wrist action....used a nela s*p*r*lex 2 yesterday and FCK me it looked rough this morning been put back in tool box till I have time to sharpen it I'm hoping it gets better or it won't be getting used again the set dried out the muckiest colour I've ever seen and troweld up about 6 times! Didn't even feel smooth etc..any1 else got 1?
What? Another one? The place is full with nela vs refina , but I wonder why neither stands against MTMate this post is about tigers and red stripe beer you can start a new thread.
I wont! Would be near same tho with a mt as shine a light against or down owt shows s**t up if u shine a light across or down a plasterboard it looks rough does the plasterboard,mite of dried out patchy because of weather as it got called wen we was doing last set and no heating on jobWhat ever you do don't shine a light down a wall after its painted that is skimmed with a s*p*r*lex.
I got a mark 1 supaflex that's nearly new used it twice it's my back up one ...i will swap you it for your mark 2 if you want?I wont! Would be near same tho with a mt as shine a light against or down owt shows s**t up if u shine a light across or down a plasterboard it looks rough does the plasterboard,mite of dried out patchy because of weather as it got called wen we was doing last set and no heating on job
Did u put a thread up about pva on moisture boards?What ever you do don't shine a light down a wall after its painted that is skimmed with a s*p*r*lex.
