thistle bond it
wil
i'm skimming a bathroom out and i've put bond it on the two longest walls, hope it does what says on the tub ;D ;D should see the walls am skimming it's as if the tiles were layed on th wall while the render was wet, cracks in the render exactly where the tiles were, like a chess board ;D ;D
sounds like one of those 1930s houses, if it is ,they done well to get the tiles off. i would let the first coat go in a bit more, to see if theres going to be any bubbles, etc, then put the top coat on. first coat allways a good teller of whats going to happen with the second coat, if applied to early.
