thistle bond it v febond blue grit v wickes bonding agent v pva water sand
thfc191
Hi guys i have used thistle bond it expensive 45 a tub 10 l is this similar to roll on as wba 15 quid 3kg or febond blue grit 22 quid 10l i've never used those 2.
What do you guys like using and why :RpS_biggrin:
I also heard about sand water pva mixture ? have you guys come across this :RpS_unsure:
What is in bond-it? I mixed some sbr and CPI render into a slurry and it looked the same! Went a nice purple colour too.
Also is microgob for out sides More or less the same as bond-it.
Pva mostly for me and betokontakt on realy high suction suction surfaces ooh matron
Knauf betokontakt is same as wickes own really good stuff When i started labouring I had to roll it on hundreds of meters of tiles and they skimmed next day amazing
Wrong way round you tit
Ive used on both I would class the old school grey plaster high suction and it saves you having to pva tons of times.
I first started using when labouring for a guy in a tesco store where i rolled it all over meters and meters of tiles bloody good stuff
Have you not used it on high suckers.
Yeah i did a job last year and when we got there the customer had covered the whole job in bond-it and we had sections were it was crazing it went ok in the end but i dont think we would of had the problem if we would have pva'd it.
some times pva just drys straight in theese are the high suckers i meant.
I use PVA 95% of the time and beto on the stuff pva is not man enough for
beto or wickes own is an expensive way to go PVA is the dogs noots
I agree the only time we use it is on concrete and silk paint other than that it gets the pva treatment.
Thisilbond/febbond both great products but pva wather sand nearly as good chepper
