J jacko001 Member Aug 8, 2016 #1 small extension in brick work.can i render it with sand cement mesh.then coat in marmaritt
D Dansouthcoast84 Well-Known Member Aug 8, 2016 #3 whats with the poll? both answers 10? yes you can aslong as you dont give wareanty
O owls Well-Known Member Aug 8, 2016 #4 If it's a small extension just use there correct Gear for the job -sm 700 is great to use, penny pinching for small areas.
Rigsby TPF Special Forces Aug 8, 2016 #5 I have used the bucket coats over sand and quite a few times with no issues. Just make sure it has dried out well and it is well primed.
J jacko001 Member Aug 9, 2016 #6 Thanks lads. Appreciate input. Sorry haven't a clue on the poll thing. Just put in random number.
MikeAtthis Well-Known Member Aug 18, 2016 #7 owls said: If it's a small extension just use there correct Gear for the job -sm 700 is great to use, penny pinching for small areas. Click to expand...
