I mixed some b&Q plastering sand with some cement and feb. It mixed up quite easy. I put the mix into the ritmo to see if it pumps through.
If it pumps through that means the gear is pumpable.
It flew through.
1 bag of sand is 33 quid cement is 3 quid odd feb is about 7 quid. that will do about 60 mts at 10mm
You can use this mix in all sorts of applications. for EG
Base coat internal and external
add SBR for rendaids, base coats that bond direct to old work or overlay
add lime for base coat for roughcast and sprayed texture roughcast that can be painted
add lime dash receiver or floated topcoat
add lime white cement dash reciever
it does tie one man to a machine and mixer so thats not a plus.
after 50 seconds turn it off i forgot it was recording
It flew through.
