The holy grail
Vincey
Of render , silicone thincoat crack resistant crack free super dooper render has .....
Cracked
Well blow me down
Ritch
Cracked
Well blow me down
Cracked
Well blow me down
All Renders are shite in this country, got the wrong climate for it. Give me a traditional brick build any day of the week. Timber frames with thin coat are a the biggest joke cardboard houses sound hollow when u bang the wall lol
FreeD
They all crack mate is the point, if they are gonna crack they will
Some manufacturers say they are breathable...are they f**k...I've had a couple blow in areas where water has got behind...basically this stuff is 0.1 on the breathability scale...basically Sandtex pant with a couple of handfuls of sand thrown in
Ritch
Silicone base render breathable lol
essexandy
The Lake Governor
Sandtex paint is breathable.
FreeD
Yes it is but how breathable? A product can can be marketed as breathable but on the scale of breathability it could be near 0.1. Would you put Sandtex paint over a lime render?
This is what I'm saying thin coat renders marketed as breathable are basically not breathable.
essexandy
The Lake Governor
Well Sandtex can go over render that has a fair moisture content without blowing off, so is breathable to a point.
FreeD
Maybe for a cement rendered property ok but the stuff is not breathable enough for any kind of heritage work...painting stones etc which it is often used for painting sandstone bay windows.
Problem is people see the 'breathable' and think OK but this paint is not ok for the majority of applications that require a breathable finish...same as with thin coat.
Ktownsend
Water getting behind render and a wall being breathable are completely different things though?
FreeD
Not in my eyes if water gets into a breathable lime render in any form it will breath out...because its breathable...if water gets behind a silicone thin coat render it may blow it gets trapped...heated by the sun and turns to vapour, expands and pressure blows the thin coat. Wouldn't happen on a 100% lime render because it's BREATHABLE!
