Temps frost proofer
ankers
What does everyone do when temps are freezing. Does anyone put frost proofer in for overnights. Wickes?
Stewie03
Wickes brand is meant to be decent ive never used it though ive either covered my work up with sheeting or just won't render on certain days if I know the temp is gunna be freezing
Rigsby
TPF Special Forces
Putting obvious freezing weather aside its what if it turns parky overnight we should be considering.
Well I have used Wickes and Feb Wintamix with good success. I have had two that did get caught and froze solid but are still there today. When I say solid is was white over with frost but under that frost it was probably ok. Feb Winta mix has air aintrainer that works from a set state but it also has an anti freeze in it that stops the water freezing so protection from wet to set. It also has accelerator in to get it set quicker.
Do we worry about our car radiator freezing? No we have confidence in the anti freeze and Winta mix has it in. Worked for me.
ankers
Cheers rigsby have you used wintamix with mono and no colour issues? This has helped me loads
Rigsby
TPF Special Forces
I have used it once in mono but it wasn’t that good as an accelerator.
Wickes worked well but I bought Larsens in bulk. Cheaper than Wickes without the chloride free additive.
