Course you add water you silly c**tHello,
Do any of you add any water to the tc15 silicone tubs, used the other day and was very thick and chewy, added some water and it felt a lot better. Thanks
@essexandyCourse you add water you silly c**t
Well done big manCourse you add water you silly c**t
YesWell done big man
You know I've never used the K rend gear smart arse. Still only used the Atlas gear and we don't add any water to it.
No problem ya F*****g chancer
Only used johnstones . I did 0.5 meter sq down side of fence undiluted and it was horrendous to fluff upYou know I've never used the K rend gear smart arse. Still only used the Atlas gear and we don't add any water to it.
Actually he's a really helpful bloke, given me loads of advice with regards thincoat.Always one bellend and that’s you, I suppose you came out your mum with all the knowledge, you miserable t**t
My inbox is full from you pesteringActually he's a really helpful bloke, given me loads of advice with regards thincoat.
I think most of us on here are more likely to offer advice to long-term, active members of the forum, and even then by DM.
Jono's needs a litre a tubOnly used johnstones . I did 0.5 meter sq down side of fence undiluted and it was horrendous to fluff up
It is even worse for those like me ‘M’ lower down the alphabet than a ‘J’My inbox is full from you pestering
More for your money .Jono's needs a litre a tub
100ml of gentleman juice for me
Why use your waterGenuine question; if all these topcoats are better with a higher water content, why aren't the manufacturers making them wetter? More profit for them that way.
You are as thick as you look aren't you?Why use your water
Not better necessarily just easier to applyGenuine question; if all these topcoats are better with a higher water content, why aren't the manufacturers making them wetter? More profit for them that way.
Your as thick as your undiluted thin coatYou are as thick as you look aren't you?
Don’t be silly how can a newborn know everything about thin coat render you thick chancing c**t.Always one bellend and that’s you, I suppose you came out your mum with all the knowledge, you miserable t**t
I’m interested got half a pack of chocolate hob nobs in the cupboardDon’t be silly how can a newborn know everything about thin coat render you thick chancing c**t.
I bet it’s easy to slip inside your mom though ain’t it, she’ll do anything for half a pack of biscuits and a can of pop that one
