Tanking help
#1
Is it possible to dab onto a tanking membrane or can you only sand and cement or fix battens? Also for rising damp is it possible to render coat 1.5m up the wall with a waterproofer in and then dot and dab. The walls have been injected
Thanks in advance
gps
Can I ask is it you carrying out this work ?
madmonk
if it's delta membrane kind of stuff yes and dab where the plugs are if you can
Love CBD
Arti
You can dab onto tanking slurry with poly insulated boards
#7
Dab onto plugs , you may need a few more plugs depending if it’s curtain fixed or fully fixed
t33ch
Thanks in advance
The stuff I use is designed for F&S or dab. Need proper plug spacing (250 c-c) and dab the plugs.
If you are going to S&C 1.5m up, you may as well keep going or float the top and skim it all.
Have the cavities been cleared? most 'rising damp' is bollox imo.
