123randy321
I live in Michigan, building code says basements need to be R-10 minimum. I am installing 2" rigid foam against the 8' exterior poured cement basement walls. This foam will be buried by backfill except for the top 1'-2'. I would like to stucco this exposure for lack of any better ideas. My problems are several;
1) Does anything go over the exposed foam before stucco like tar paper?
2) I plan on using wire stucco lath but how is it attached to the cement walls through the foam?
3) Should there be a gap between the foam and wire lath to bond the stucco to?
4) How is this gap controlled?
5) What is going to keep the foam from flexing and cracking the stucco? I can glue the tops of each foam sheet to the cement but will this be enough? Foam glue is not the most impressive stuff.
6) Answers to all the questions I am to dumb to ask
I have considered attaching treated 2"x2"x2' strips in slots cut in the foam approx. 16" apart using cement screws then attaching the wire lath to them - best idea to date. I am an experienced builder but I have never stucco'ed before.
I welcome all comments from small to large to a completely different approach.
Thank you in advance
Randy
Randy
