Spraying K rend HP 12
PFTwales
Sprayed this today succesfully with a Ritmo. It must be sprayed quite wet but it does stiffen up very rapid.
plasterjfe
Sprayed a fair bit of this but you gotta keep moving. The new improved " longer working time" formula did nothing IMO. How did you find? Any different to the old formula
PFTwales
we using it for mesh coating over a painted surface prior to a 1.5mm topcoat. I was able to leave this in the tubes for over an hour just like any other render that we pumped. previously it wasnt worth spraying cos it was such a ball ache
cjs
What water and speed setting Blones?
by the way the blue chiness stator you sent me foc to try lasted about 120 bags so you were right about um.if they were cheap enough they would be ideal for just spraying base coats then chuck away.
the new mixing shaft for the ritmo has made such a difference genuinely surprised by how much.
PFTwales
good, i dunno how much they are i wont be selling them. the new b 4 1.5 stators with seperate clamp are cheap enough.
water 225 speed 7 on the ritmo L not sure on the M yet
